Help on best options!!!!
movinalong
greenwood ms
I'm purchasing an 88 dodge ram 150 sc/sb auto with a 318. The guy said the carb is no good. The truck is a long way from my house so I was planning on taking a manifold and carb with me. Any suggestions will be welcome an very helpful on what the best products to purchase.
rusties93LE
360 magnum
Edelbrock intake/600 cfm carb, intake gasket kit,t-stat & housing, rubber fuel line and clamps...
crazzywolfie
under the truck
since it is a 88 with 318 it should be TBI and NOT CARBED. big difference but look the same
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
^Unless someone converted it over to carb...which might be the case since it doesn't run.
crazzywolfie
under the truck
could be but people always confuse the 2 since they do both look similar but there is a huge difference.
movinalong
movinalong
greenwood ms
Ok if it's tbi it should be easy to convert it tho right just need a fuel pressure regulator?
crazzywolfie
under the truck
that is a carb so someone must have converted it. i would wonder if the issue was with the wiring
movinalong
movinalong
greenwood ms
I dono but it's a 500 mile round trip for me I'd like to see if it'd run before I drug it home. He said it had been running until about 2 months ago
movinalong
movinalong
greenwood ms
Cool thanks for your help. You seem to know are those engines worth a head an cam swap or should I just look into other options?
crazzywolfie
under the truck
as long as there is nothing wrong with the heads you should probably just leave them be. i don't think you will really find better head for them unless you want to spend way more money on the engine than it is worth. now changing the cam might make a bit of a difference but i think a cam for that engine might be a bit more expensive since i am pretty sure 88 was the first year they started using roller cams in the trucks.
movinalong
movinalong
greenwood ms
Well the truck I've been buying parts for is an 11 with a hemi an while old it's still mopar. Everything is high lol.
movinalong
movinalong
greenwood ms
Can you recommend a good site where I can look up things like that? I'm lost on older mopar stuff
crazzywolfie
under the truck
i am not really sure of the best place to get a cam for them roller engines. i think you can get reground cams but still not sure. not too familiar with the later LA engines. i think you might be able to use a cheaper cam with the later engine but i think you would have to change push rods since i think push rods got shorter when they switched to roller cams.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Probably just start searching Summit. Just need to make sure you have a roller engine or not.
movinalong
movinalong
greenwood ms
I was wondering that was 88 a cross over year like 1/2 tbi roller 1/2 old school or something?
crazzywolfie
under the truck
kind of. 88 was the first year that the 318's were TBI and i am pretty sure it was the first year that roller cams were used. the only engine that stayed carb was the 360 but it was converted to TBI in 89
movinalong
movinalong
greenwood ms
Does that mean it could possibly be a 360?
