Help on deciding which amp and sub I should add to my 2019 Ram Bighorn Crew Cab.
BJSforVols
USA
Hello,
I am upgraded my factory system (it was the base 6 speaker system with no factory amp.) in my Ram Crew Can truck so that it will have new, aftermarket speakers, an added 10” low profile sub, and an added amplifier. I have already got the speakers installed and they are all the Infinity Reference speakers. (A pair of 6x9s in the front doors which are connected to 3 1/2” in the front dash as well on channels 1&2. Then a second pair of 6x9s in the back doors on channels 3&4)
I’d like to add a nice 10” sub that does not require a lot of air space and has a 3 1/2” mounting depth or less as well as a 5 channel amplifier. What amplifier do you recommend I consider and what 10”subwoofer would you get?
San Diego
2019 RAM Limited
5.7L HEMI
You might want to cruise over to the 5th Generation Rams forum on this subject. There is a ton of info and pictures. Quite a few of us have done this addition. I myself went with a Supercrewsound box, Pioneer subs and amp in my Limited. Not sure whether set up will fit in the Bighorn but this will get your mind started on the subject. One thread among many: https://**************/community/threads/sub-woofer.1885/page-6
akrausz
USA
I chose an inexpensive Jensen amp from Walmart. It has no controls on it, everything is done via a phone app. I wouldn't run the dash and front door speakers on the same channels. You need to control the levels individually.
