HELP!!! Truck shuts off when I hit a bumb!
Dodgegirl711
Clinton township Michigan
I have an 07 dodge ram 1500 mega cab and when I hit a good size pot hole or rough rail road tracks my truck shuts off. I have checked the battery connections and there good. It did come with a factory remote starter if that matters. Any ideas?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
This is only a wild guess, but you may want to check the different Ground Connections
There are Body Grounds, Engine Grounds, Frame Grounds, etc.
chopperman1
2018 Rebel
5.7L HEMI
It wouldn't be a loose battery connection, a running car/truck does not rely on the battery connections to keep running. I would start with checking all electrical connections to make sure they are tight ans seated correctly.
Dodge 1500 4X4
Rochester, NY
Make sure all your fused and relays in the fuse block are seated.
