Help understanding
MuleDawg
Tuscaloosa, Alabama
So what I’m looking for is to add the following: subwoofer that goes under the rear seat, an amp to push woofer , but I don’t want to lose my factor head unit.
If someone is sealing the woofer, please feel free to hit me back other than that let me know or show me your mods. Thank you.
mjscharlotte
Charlotte, North Carolina
5.7 Hemi V8
Hey MuleDawg,
I've got a 2018 1500 Crew Cab and I put (2) 12" Tezla subwoofers under the rear seat. I used a sealed FoxBox specifically made for the truck and I also installed a 1600 SoundDigital amp. My truck is a "Limited" trim model so I have the 8.4" head unit which performs fine for what I wanted. You didn't mention if the truck is a reg cab, quad cab or crew cab and which radio you have. To answer your question - it's no problem installing an amp and a suborder the rear seat and keeping your factory head unit. You just need to decide how big of a subwoofer you want and then get an amp strong enough to push it. I also changed all the door speakers, dash speakers and overhead speakers and have a second amp for those. I would also consider looking at some sound insulation otherwise you will have some rattles with the bass - plus it will make the system sound better if you ever decide to replace factory speakers. Good luck and have fun.
MuleDawg
MuleDawg
Tuscaloosa, Alabama
Brother thanks for all the information and here is the skinny on my “Silverback “
2014 Dodge Ram Big Horn 1500 I have the short bed and all full size doors.
I’m gonna look into find the sub boxes as well as amps. Do you have any suggestions on where to get the boxes for the subs from? Thanks again
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I had this, single 10" with 200 watts, did plenty, and hooks up to factory radio in about 30 minutes.
mjscharlotte
5.7 Hemi V8
Frank Lee
Your Moms House
sorry about the necro, just wanted to put out there that FoxAcoustics is circling the drain. i finally cancelled an order that was placed in AUGUST of last year with customer service pretty much ghosting
