HELP!!!! windows stopped working!!!!!
BIGBREW
Today I Turned My Key To The Acessory Position, Rolled All My Windows Down, Got In Truck, Started It And Drove About A Football Field, Rolled Up The Windows And Ran In The Store, Came Back Out Started Truck Tried Rolling Down Windows And None Of Them Do Anything.....2008 Ram 1500.......Help Its Finally Nice Out And I Cant Roll My Windows Down!!!!!!!
B
BIGBREW
Had To Leave For Work Did Not Check Switches On Other Doors, The Lock Is Not On, I Checked The Fuses They All Look Ok, But I Dinner Know What One It Is, The Owners Manual Does Not Say Which Number Dude Either, I Need Thus Fixed Asap!!!!
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
First start with the switches on the other doors when you get a chance after work. If they work, pull your driver door panel and check voltage at the connector to your window switches. If there's voltage getting through then your switch assembly is bad.
Sent from my DROID RAZR using Tapatalk 2
