Help wiring aftermarket mirror
Stephenpresley
Ft drum
Wiring power mirrors that have a puddle light, turn signal, running light, and heated. The factory harness controls the mirror and the heated part. I bench tested the mirror and everything worked. But now with the mirror installed, the power mirror part works but the puddle light, blinker and running light doesn't work, unless I unhook the factory harness for the mirror and heater and hook up a ground straight to a different ground on the body or my test battery.
Should I run another ground off the factory harness to the body?
Any assistance would be appreciated. 7197618675
