Help with buying tires for my truck that is unlifted and not 4X4?
eddiefan
Hi im new here, i have a dodge 1500 truck 5.7 liters, not 4X4 with stock rims but the wheels are 285 50 r 20, i kinda want bigger tires with a more tougher look. Will it look good with 295/60/20 tires? would i need a lift or can it look good without it?
quietpeen
2021 TRX
Hellcat
you might be able to squeeze them in with just leveling the front. They will not fit on stock suspension
LS5DodgeRam
South Florida
4.7L v8
I had 305/55r20 and they rubbed hard. I have a massive hole in my fender well and my mud flap rubbed against the oaint and dug into the paint to bare metal. Be ware wirh larger tires juat a hwads up. I went into it knowing they would rub but not rhat bad. But I have a lift now and they are fine
Edit: mind you I had 20x10 inch rims with -25 offset
TMFMK
