Help with Suspension
Silverbullet08
Persona Non Grata
Alright guys well i was riding in the truck today and started playing around. so i ended up just flooring it and damn:drool: the ass end just went out lol
im putting the cam and lt headers in october so i want to start saving up for suspension/handling mods to help with that. should i go with the hellwig sway bar or caltracs first? is there anything else i can do? thanks guys
kay9
Banned
xxxx
xxxx
Sway bar for cornering
Caltracs for the straight line launch.
If you dont have much wheel hop then maybe the Swaybar first.
Caltracs if you have bad wheel hop but just adding drop shackles can help with that.
Neither really helps if you have bad wheel spin.
S
Silverbullet08
Persona Non Grata
thanks. i can run them both with no problems right? i have drop shackles already. it was seemed like a little spin but mostly a hop i think
truckin151
2013 sport
really need the flip kit for the caltracs but you can add the extra peice to the setup for $40 or so to work with the shackels.
kay9
Banned
xxxx
xxxx
I don't think you will but i can't say for sure for being 4x4. I run a Belltech Sway bar with Caltracs on a 4/6 drop with no issues but i am 2wd.
EDIT: I thought you were 4WD so scratch that first sentence
Got_Hemi44
Dayton, Ohio
Shouldn't have any problems. I emailed both hellwig and caltrac asking if everything would work alright. 2wd or 4wd is irrelevant for the rear. I'm a 4x4.
This is what I'm running in the rear:
2" drop shackles
O/L removed
Nitro Drop 2 Shocks
Hellwig Sway Bar (just bought on DT need to install)
Then Caltracs when i get around to buying them.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Here's a picture of "neverdone" one of my all time favorite trucks.
kay9
Banned
xxxx
xxxx
x2. Just noticed he has the same bed cover model as I (Innovations Fiberglass GT Spoiler Tonneau). First for me.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
DT has a set of traction bars powdercaoted silver for 200 and you could prob talk em down some.
S
Silverbullet08
Persona Non Grata
link? couldnt find them
nvm i found them i dont have a flip kit though
Redtruck-VA
Virginia
Drop that bad boy.....
Redtruck-VA
Virginia
nah i like where its at right now
Ok,
This might be an approach that would give you a lot of flexibility. Install a flip kit, which allows the standard Caltrac install. And then with custom shackles you could dial the rear to the exact level you want. It is a bit convoluted but might be considered a step forward if you are every considering a different stance. Or I think Caltracs has a kit for stock mounting for something like $40. Just thinking out loud.
Hemiguy0302
Edmonton Alberta Canada
6.2 Boss
I wouldn't bother with the hassles of a spring under and all this ******** for a truck that probably will not be modded too much. If spinning is a concern throw a 100lbs of weight against the tailgate. Running street oriented tires is not helping either.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Yep, and Something you should consider Silver which I am seriously considering doin when the gears go in.
P.S. Swaybar is def on my list too But dunno Hellwig Choice 1 vs Belltech Choice 2 ??
Crapo85
