Help With Unfreezing
memphisflyer
Cummins 6.7
I'm relatively new to diesels. I have a 2020 3500 with the 6.7. It got down to about 1F here a few days ago and the truck won't start. I know now that I should have used an additive and I certainly will next time. My issue now is getting the truck running. The truck says to service the fuel filters so I assume the filters have thick waxing fuel all over them. Now that the temp is around 40F, can I out some heat on the filters with a heat gun and get things going? Or am I going to have to replace the filters? Any help is appreciated.
turkeybird56
Central Texas
U want to throw unregulated heat at an area with fuel filters, ahhhhhhhhh, U may want to rethink that. Change the filters, if they R all gelled up, they be trashed ne way. But this is just my opinion, OP U do as U see fit, but heck yeah, anti-gel for the future for sure.
ADDED: If U just think U gotta throw heat at it, use a Hair Dryer, not a heat gun. You can regulate a hair dryer some, but a heat gun can get as high as 1,100 degrees, just a thought. AND I do not recommend this, just a FYI.
M
memphisflyer
Cummins 6.7
Thanks turkeybird. I was thinking hair dryer when I talked about the heat and yes, super careful heat - I'm not nuts:) I just wanted to know if the heat idea was even worth trying since getting the fuel filters today is going to be a challenge. Thanks for the input.
turkeybird56
Central Texas
I personally WOULD not do heat, put in heated garage, but really change filters. U can go Fleetguard, see this thread, few posts downn, U should be able to get these easy.
JUST check on the part numbers and insure proper for yer Diesel, as I have not played with Diesel much, and when I did, it was either a Military M35A2, 5K generator, or my RAM ED which I no longer have. There are a lot more knowing PPL then me in this forum to assist U.
ppine
Forester
Nevada
6.7 liter diesel
At 40 degrees you should have no gelling even with No 2 diesel. Go to a truck stop or good parts store and get a can of diesel additive in the big white can. It takes out water, adds cetane and helps with gelling. There is also an emergency additive in a red can. Both of these should help.
Dean2
Near Edmonton
If you want to win the Darwin Award, put heat on fuel systems. Absolutely brilliant idea.:893Chainsaw-Smilie-
You already know the right answer, just do that.
M
memphisflyer
Cummins 6.7
Thanks folks. First post here and lots of comments about my dumb idea. Perhaps I was questioning the idea too but thought some advice here might be useful. I think I'll find a forum with a few less snarky BS comments. Thanks to the folks that offered rreal advice, it's much appreciated.
Dean2
Near Edmonton
Even the snarky one, and there was only one, was quality advice. There really are such things as dumb questions. You would not believe how many troll questions of this type get posted on here looking for a rise. Hope you have better luck elsewhere but you may be a tad too sensitive for social media.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Call your local shop. There is emergency melt down called 911 I believe ! Made for when a tank jells ,, We had cases of it for all our trucks ...
RamDiver
Marlborough, Ontario Canada
2021 DS
I didn't think that was nasty and barely snarky.
I nearly spit cold coffee on the screen when I read it, though.
Thanks for the entertainment, keep it com'in please. :cool:
Dean2
Near Edmonton
I am the Contra Canadian - Not Polite, Not Humble and Rarely Apologise. Trying to change Canada's image cause with Truidiot at the helm, it really needs changing.:)
turkeybird56
Central Texas
It was not a Jimmy Stewart Classic, he just said what I said but maybe a bit more Direct? lol ...
turkeybird56
Central Texas
Awwwwwwwwww, U run around with a Smoky the Bear Hat and Red Jacket on, and not at Xmas time? LMAO...
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
You can put an open flame to raw diesel fuel and it doesn't catch immediately, the OPs idea of using a hair dryer isn't a problem but probably won't do much for the gelling. Your attempt to be snarky was ill fated.
Dean2
Near Edmonton
Raw diesel, true, even raw gas, you can toss a lit cigarette into a bucket of it at 32 F and it will just go out. HOWEVER, get vapour from either and instant ignition from open flame or even a glowing surface like the aforementioned cigarette or the heat element of a heat gun. Try the same lit cigarette into a bucket of gas at 80 F and you will immediately see what the existence of vapour causes.
Does it not enter your mind that heating diesel is likely to create volatile vapours? or are you simply focused on trying to prove the rest of us who were against using heat, wrong.
Also, like you said, the heat won't solve the waxing problem anyhow. I have started a ton of gas and diesels at -40 and colder as have others. You do learn a few things living in this climate for almost 70 years.
06 Dodge
6.7L CTD
You have to change the filters because the wax crystals ruin filter media, if its still gelled you need to use Power Service 911 to help thaw it out, once running add a good dose of Power Service in the white bottle to help with water and to keep it from gelling up again. Good Lucky
Reticle918
