Hi Folks
I have a 2012 Dodge Ram 3500 Diesel. I am putting on 4 Hella Ralley 4000 on a light bar. These lights I have converted to HID. I want to wire them in a 2 switches on the dash. One switch for each set of hellas. I need to tie them into the high beams so the come on and off with the high beams but are also controlled by the switch in the cab. The switch in the cab would just control whether the road lights would come an on at all and the high beam circuit would control when they would come on.
I can handle the wiring but does anyone know where the easiest place would be to tap into the high beam circuit. The high beam circuit would trigger the relay to take power direct from the battery to fire the lights.
Any help from someone knowledgeable would be appreciated.
