Help!!!!!!
Cdiaz1102
5.9l
So I have a 2002 1500 5.9l..... I was driving when my charging gauge went to zero and check gauges lite lite up..truck ran fine...... Then about 2 miles later my dash lite up like a Christmas tree!!!!! Truck strarted running super rough and when I parked it and tried to start it up no go..... Would crank then battery would die. I charged up battery and replaced alternator..... Still wont start..... I was able to get it started by holding down has petal but as soon as I let it go truck dies and battery dies as well..... I really need some advice for this is my work truck..... Any help ?????????
bhonshell37
Washington
Will your truck start if you put the positive cable on the alternator and the negative on the battery?
C
Cdiaz1102
5.9l
Haven't tried that yet...... What if it does?
bhonshell37
Washington
Then either the battery is bad or the alternator is bad. Check all your grounds to. The connectors on the battery cables need to be free of any play
Ram Lover
Maine
5.9L 360
Sounds like alternator to me but, if you didn't get connections tight after replacement you'll have the same issue.
Sent from my SM-G920R4 using Tapatalk
