Trey1123
I have a 2017 ram 5.7 and the rpms are all over the place. On start up the rpms will go to 2,000 rpm and then drop to 1,000 rpm or it will drop to 1,500 rpm and start bouncing between 1,500 and 2,000 rpm or it will drop to 500 rpm and almost stall but doesn't. I have replaced the throttle body and can't find any vacuum leaks. The code it shows is p0507 and p2173
