Hemi Tick? Exhaust Leak? Please help!
FancyStancy
Cummins 6.7
I have been noticing a noise coming from my passenger side, under where my passenger side floor mats are. When I first heard it, I figured it was one of my electronic exhaust cutouts. I have a cutout located where the noise is coming from, and I figured I needed to tighten up the set screws and mounts. The noise sounds almost like the cutout is a little bit open and it's flaps on acceleration. I have tightened the cutout and mounts and have used TB cleaner to clean the carbon buildup. Still makes the noise. There is no noises when de-accelerating. The ticking doesn't happen when slowly accelerating or at higher rpms. I have heard some people saying it could be a bad catalytic converter, but I still have the tick when I have my cut outs open (by passing cats, direct dump from header). Doesn't sound like a lifter (which is what I hear is what the hemi tick usually comes from) because the noise is directly under the passenger side. If it would help I could maybe take some videos later today but maybe some of y'all could help me out with this info. Thanks
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
You can jack her up and slid under there and listen carefully. Not sure how you can hear anything with a cutout open?? Can also use a rubber hose to listen with to really isolate what you hear.
FancyStancy
FancyStancy
Cummins 6.7
I listened very carefully around the cats and cutouts. I hear nothing. It makes no ticking at idle. Just when accelerating
La ratilla
