W69DY
- Feb 15, 2015
- 87
- 14
- 2019 Rebel 12
- 5.7 hemi
Ok so I finally ran 3 tank of premium fuel through my truck. How do I log the information to send back and have adjusted for my truck? Read below for information needed to build custom tune.
From hemi tune:
I will only need a log of the premium fuel tune whenever you get nothing but premium fuel in the tank and run that tune (if ur running low octane and switch to high you will need to run through 2 or 3 tanks of premium fuel before the log will be accurate) . Log about 5 minutes of part throttle simple stop light to stop light driving and a 0 to 75 mph full throttle run. You can do this in a single log. The log will autosave into the logs folder when you stop it. log the below items for me :
Cooling : Engine Coolant Temp (ECT)
Ignition : actual spark cyl 1 (or spk adv 1)
Miscellaneous : P-Ratio Map, Desired FA Cyl1,
Misfire (or knock control) : KNK ST Retard, KNK LT Retard, knock sensor 1 and 2 volts
Performance : Vehicle speed and engine rpm
Intune Datalogging steps : Start the engine and let it idle. Plug up the tuner and let it boot up. Select scan tool, click yes, select datalogging, select configure, select pid select, then add in the additional PIDs that I requested,when done adding click back button, then click record. At pid select, it'll display the current pids that are pre selected. Scroll to the bottom of the list to add in additional pids
From hemi tune:
