If it was it wouldn't have throttle lagEdge Pulsar is a real tune
Sorry couldn't resist...lol
And can't forget that diablo unlocks aren't actually unlocked.
Do you happen to have the part number or where you bought it?To fix the speedometer, you can buy the AlphaOBD/OBDLink MX+ setup. You can change the tire size with it and it can also act as a scanner as well as add factory options if you are interested in doing that.
The air box mod is using the lower box/and or just the snorkel off of the ecodiesel and 6.4. I just bought the snorkel and cut the stock air box and installed the ecodiesel air filter.
The 6.4 intake manifold is supposed to be a nice mod - but only the 6.4 intake manifold off of a truck.
That is shady, does the hp have canned tunes or is it custom only?Diablo only unlock the PCM to work with them. Thats what is super shady about them. I dont have that issue with MY12 ****box, they werent locked back then... lol.. . Join HiPo rams on FB way better info on there compared to here.
@Wild one Do you remember if HP unlocked PCM work with diablo , I having a brain fart and cant find the tread on High Performance Ram FB page.
It's custom,HP is just a program you buy and then you can adjust things yourself or have a tuner do a custom tune for you. Rick Tapp is one of your better bets for unlocking your PCM,as he doesn't lock them to either HP or Diablo.That is shady, does the hp have canned tunes or is it custom only?
Ah yeah probably lol thanks for pointing that out. Do you know if both of those or which ntake manifolds fit the 5.7? Id like to do the manifold plus box/filter/snorkelIt’s actually the 3.0 diesel lower air box or 6.4 hemi lower air box. May be why you’re having an issue.
@AllMoparParts.com do you have a link for the 6.4 hemi truck air box
The new manifold would not require a tune to run properly right? I get the tune would maximize proficiency though.
The 5.7 doesn't use the Mass Airflow sensor right? Did you plug that hole in the 6.4 airbox lid? I don't remember that from your thread.When you do the 6.4 manifold you’ll need to buy the upper half of the air box as well as the tube
