hesitates when i step on it
karl g
I have a 2004 hemi 5.7. When I step on the accelerator and it shifts into passing gear the truck begins to hesitate and spits &. sputters. I'm wondering what is causing this
PCA4208
Albuquerque, New Mexico
Bad gas maybe? But also the passing gear is the weak link in these transmissions. Use it too much and she'll take a *******. It should be used sparingly if at all.
K
karl g
The truck is A 2500 4 door long box with the factory towing package
K
karl g
Yes it has original tranny. It Does the same thing if i punch it from a dead stop. Im thinking its an engine issue or a problem with the catalytic converters
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Typical stuff, like dirty TB, plugs, cats could be a problem but you usually throw DTC if anything goes bad with them.
