crazzywolfie
- Joined
- Apr 6, 2013
- Posts
- 16,433
- Reaction score
- 3,195
- Location
- under the truck
- Ram Year
- 81 93
- Engine
- 5.2
rebuilding the steering coupler is cheap. you can do it for about $10 or so depending on if you have all the proper tools. you would also want to grease the coupler good. that should help it last longer if you rebuild it. i have even seen people add a grease nipple to their couplers. you will need a 12 point 3/8" socket no matter what route you go. you may also want to start spraying the bolts on the steering shaft with penetrating oil so that they should not be too hard to take if you plan on rebuilding the coupler soon.
