HID Frustrations.
Jcasey10
Springfield, MO
Magnum 5.9L
I've got a set of HID's in my headlights and fogs, and right now I'm waiting on a resistor harness for my bixenon kit in the headlights. Well ever since I've had the fogs put in, they won't stop flickering. It's not an on-off flicker, it's as if they're shaking in the housings. I've gotten a set of cancellers and a set of capacitors and neither one of them have fixed the damn flickering. I bought the kits from hidnation.com. Is it because they are a cheap kit that they do this or could they just be faulty and I need to return them for a new set? Or is my truck just retarded?
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Wait for it...
EDIT: Sorry man, just figured JJ (our HID and headlight GOD) was gonna chime in. He might be on later. I had a similar problem, but with buzzing when I turned on my radio. Problem is always ****** ballast construction, or improper wiring.
Like I said, JJ will chime in soon, and let you know what cha need.
If it does end up being crappy cheap ballasts, purchase a set from his, he uses Retro solutions, and they have excellent prices, customer service is something messes up eventually with one of them, and they're ballasts/HID's are top notch. Most of the guys on this site have at least 2 sets installed.
Vendor
Florissant, MO
2x 5.7L & 6.2L
Josh - my cheap ebay fogs did this too...............I replaced them with ones from Retro-Solutions (which I resell too!) and they kick ass
Jcasey10
Jcasey10
Springfield, MO
Magnum 5.9L
I figured it's because they were a cheap kit. I actually bought my capacitors from Retro-Solutions. Do those kits have any problems with flickering?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
in the fogs? no.
Heads are tricky - but Retro-Solutions has awesome kits for those too!
Just remember, use coupon code "JJ" over there and you'll get 10% off eligible items. :D
Jcasey10
Jcasey10
Springfield, MO
Magnum 5.9L
in the fogs? no.
Awesome, thanks for the code. I don't mean to keep pestering you with questions, but would 35W be more prone to flicker than 55W? I'm looking at the 55W Digital kits and they look damn near bulletproof.
Jcasey10
Jcasey10
Springfield, MO
Magnum 5.9L
I have heads and fogs from them, and never ad a problem, nor have I ever heard anyone else having a problem with they're products, just FYI.
Thanks for the info, man! Retro seems like the way to go.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
the wattage won't matter. The 55s kick ass! bright as the sun. :D (well, close!!)
JET
Arlington,Texas
1996/2011 Ram 1500 Sport
5.9 Magnum/Hemi 5.7
I have a set of Retro 55w Digital HID's for my low beams:drool:. No flicker and about as bright as the sun. Fukken awesome.
Jcasey10
Jcasey10
Springfield, MO
Magnum 5.9L
That's the direction I'm heading as soon as I return the pieces of ****!
capebreton1967
