HID suggestions
Steveo1081
I have a2014 express crew cab and I wanna do HID lows and fogs but I seem to keep getting mixed answers. Anyone that has done this can I just do the canbus install with just plug and play? Please help
jzales
On my truck the canbus did not work but a relay harness did. I have a 15 express and from what I read they are very picky.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
You have duals correct?
bobbo7915
Massachusetts
CTD 6.7L
the 2014 express will have quads unless it is a black edition which would have projectors....either way the canbus adapters are the easiest way on 2013/2014's, the only difference is the bulb type. the 2015 Rams are a different story as mentioned above.
PNUTLT1
California
All you need is a HID kit for each of the pair of lights you are doing and a resistor relay harness for each of the HID kit. The relay resistor will provide the truck with the right resistance so you will get no error codes or flickering. I installed mine like 3 days after I got my RAM and I have not had any problems. Do not get a anti flicker pair of resistors that just plug in! They suck and they blow up all the time. This is what you need; 1x 9005 9006 9140 9145 H3 H8 H10 H11 HID Xenon Fuse Relay Harness Wire Resistor | eBay
You will need one harness for every kit you install. So one for low beams and one for fog lights.
:buffer:
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
