Hidden Lights
Coastie
Oakland County, MI
Has anyone installed lights behind the grill?? if so, how did you do it? And does it work pretty well?? I want to do this but im not sure if itll even be worth it.
triangleman29
CO
Yes, there has been a number of folks on here that have done it. Looks pretty good! There are a few post about this just do a quick search!
triangleman29
CO
Offroad Lights.. I pulled up a few pages. There was a thread that had some good pictures I'm trying to locate that for you now!
Texasez
Dallas tx
I did it in mine. Mounted them on the top support. There's a cut out on each side and I drilled a small hole on each one for the bolt to go thru. Very easy. Can't see them much behind the grill until their on.
C
Coastie
Oakland County, MI
Plus is it difficult to wire it all u. ive never done any work with lights before, is it hard to do? How about the switch inside the truck, does a kit come with it or do i have to buy it separate?
TheMaddog
DFW
I did mine on my old 08, you can look up my build, I should have pics.
TheMaddog
DFW
Very easy, pretty much just connecting the + wire to the battery, then the - to the ground(metal) then hide all the wires, put the switch inside, through the foot well. Boom, you have yourself behind the grille lights.
C
Coastie
Oakland County, MI
Nice thatsounds pretty easy thanks.
how do i ook up your build though,still pretty new to the site
Texasez
Dallas tx
Its more visible because the flash. Most of the time its hard to see. When you pull the plastic cover off you'll see the spaces on the top. Just drill holes big enough for your lights and mount them and aim them. I used a remote switch so I didn't have to run wires inside. Mine came with the harness and relay but I used the other. Run one line to a ground. One to the battery then run your switch somewhere.
joshhhh
