HID's flashing
atticusfaul
Boise
OK...so I bought ebay HID's. I know I know but JJ's weren't in the budget right now so it is what it is.
At any rate, I followed the instructions and turned on the car and the HID's flash at a consistent "pulse" and the "head lamp out" light on the dash comes on. Will an "error code eliminator" do the trick or do I have something else way out of wack?
Thanks!
Litenyaup
Not sure what year u have but one of these is what you would need.
eBay item # 111054619721
eBay item # 271050956466
eBay item # 310653038588
I had an 02 and the first set I put in did the same thing. I put resistors in and the flickering stopped. I then purchased a set of 55 watt plug and play kit and didn't need and resistors or harness.
eBay item # 370788453404
atticusfaul
atticusfaul
Boise
So I ditched the ebay lights and bought HID's from JJ...still having problems though.
First install didn't work because the pins were wired wrong on the harness so the supplier sent me a new harness and you can see the wires are repinned in a different configuration.
New problem - I have no low beams. Highs work fine but I have the lamp out blinking inside the truck and no lows....thoughts please???
atticusfaul
atticusfaul
Boise
Update...high beams are stuck on when I have low/high on. Here's a pck of the harness for what it's worthImageUploadedByTapatalk1367939037.622817.jpg
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I talked to the guys there today, they should be getting you cared for on the parts to resolve.
Sorry about the mix up there!
joshhhh
