HIDs
jboy2015
whats the consensus around here? When i had a chevy i used DDM, but their stuff it hit or miss as far as quality goes and its a hassle driving to the OC to switch it out
Please dont recommend DDM.
AcerOne
'13 Ram 1500
5.7 hemmskii
I used absolutehid.ca for mine. Its nice to have a company that asks you all the questions during the ordering process about your vehicle to make sure you get the right ones for the right car. True plug and play as well. No additional resistors with their CANBUS kits and all components are warrantied for life. It is in Canada so prime time for the US guys to have your dollar go a lot further.
adurm
FL
2015 RCSB
I would suggest retroshop.us. He is a vendor here and knows what he is talking about when it comes to ram trucks.
adrianp89
Tampa Bay, FL
I looked at these, I like the idea they are truly plug and play.
Etroze86
Grand Forks ND
JJ at theretropshop has been my source for our trucks. I has provided some great help when wiring and I believe most all of his stuff is pnp.
adrianp89
Tampa Bay, FL
From the pictures on his website it looks like you still need wire 12v and ground. Can anyone chime in on this?
Etroze86
Grand Forks ND
I'll have to check but I believe the only thing extra I had to do was add a ground.
J
jboy2015
Thanks man, i dont mind adding a ground. Ill be putting these in the same time as my big 3 and replacing my 12w6v3 with a tantric!!
Would you happen to know his username on here?
Etroze86
Grand Forks ND
He has a vendor page. His screen name is a bunch of numbers
Sent from my SM-G920V using Tapatalk
AcerOne
'13 Ram 1500
5.7 hemmskii
Easiest install ive done on a set of HIDs and ive done a lot of them. No messing around. Really nice perk to their kits for sure.
J
jboy2015
thanks man, i just emailed him rn :favorites13:
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
If you have a 15........there will definitely be a few grounds to make. Here's the wiring on a set of our '15 kits:
Ricky91
