High beam indicator w/bixenon projector
Stangshcky12
Oshkosh, WI
5.9 Cummins
So I put my retro fit head lights in last night with the morimoto molar harness
The high beam indicator is on on the dash with the low beams and goes off with the high beam
Can this be fixed by switching the pins on the projector solenoid or is it a different pin in the harness that needs changed? I know I've read about this before, it seems there was a whole batch of harness that went out around November that were backwards and did this but I can't seem to find the threads with the fix
LB3711
Trumbull, CT
3.6L V6
You retroed them? Hi and low are 2 separate circuits. There's a crossed wire somewhere.
Sent from my Samsung Galaxy S4 using Tapatalk
Stangshcky12
Stangshcky12
Oshkosh, WI
5.9 Cummins
Yeah, finally got them in last night
Mini h1 and morimoto kit and molar harness
KAKA
