Hit a curb, knocked out clock spring!
BigWhiteSnake
Morris Plains, NJ
5.7L V8 HEMI MDS VVT Engine
Not sure where to post this. I slid on some snow and ice the other day. Threw the left front wheel out of alignment. Shop got it aligned, but the traction control and cruise control don’t work. Truck is throwing a hard code for the clock spring. WHY???
McBroom
Denison Tx
Hemi 6.4L
Not heard of a clock spring in the suspension. But sounds like the wheel speed sensor ring or the sensor itself.
@JB1 might know.
Blue Mule
BigWhiteSnake
BigWhiteSnake
Morris Plains, NJ
@JB1 might know.
Blue Mule
I was thinking that too. Wouldn’t that throw a separate code? Right now it says out of range for the clock spring.
McBroom
Denison Tx
Hemi 6.4L
I'm not familiar with the "clock spring" term.
Blue Mule
McBroom
Denison Tx
Hemi 6.4L
SEMPER FI
Devil Dog.
'88-2000
1st Force Recon
Camp Pendleton
0311,0317,8541,8542.
By far the best mos was being an 0317.
Blue Mule
Lil John
Seattle
Drive it straight over 9mph. 5-6 times.
Dont ask how I know but the light will go away after driving for a few. Mine did.. took me half a day and I drive for a living so 40-60 miles.
McBroom
Denison Tx
Hemi 6.4L
The truck use the steering angle along with yaw rate, speed, etc. to determine how to apply the the vehicle stability control. It probably has to be within a percentage of what the power steering unit feedsback also.
BigWhiteSnake
BigWhiteSnake
Morris Plains, NJ
Yes, the steering angle sensor was thought to be bad, but physically tested good. Not sure what knocked the clock spring out of wack. They did try to reset the system and it still showed a value out of range. Thankfully, nothing got bent. Just rash on the rim with no leaks or bends.
Sherman Bird
Houston, Texas
The alignment shop should have recalibrated the steering angle with a scanner. The steering wheel is now off center and the yaw sensor and it are no longer calibrated. The toe may have been improperly set.
BigWhiteSnake
BigWhiteSnake
Morris Plains, NJ
They called me as soon as the alignment was done. The scanner could not reset the steering angle. Everything works again. $800 later.
