Hitch Shank
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Did I read somewhere that the HD's come with a 2" hitch adapter?
opie
Mine came with one. Its under (in my truck) the rear driver side seat.
mtofell
Buy an extra.... I lost mine by forgetting to put the pin in once (hope no one was right behind me :))
Overall, I hate the setup. My locking pin broken shortly after I got the truck and I believe it's due to the rattling and banging around that takes place with the setup. I don't know why they had to screw with such a well established thing.
loveracing1988
Clarkston, MI
They did it because the 2" receivers are only good to 10k or 12.5k, which is below the tow capacity for these trucks.
derag2
6.4 hemi
Because truck capacities now at exceeding the class 4 hitch so now they run 5 on everything so they don't have to have multiple Hitches everything is the same.... If you don't like the adapter buy new receivers with a 2.5.....
opie
Thats what I did. Purchased an adjustable class V insert.
MADDOG
Living in a Firepit
6.4L HEMI
I gave up on the adapter and just got a class v adjustable hitch.
stoney
Ontario
2015 | 2500 SLT CC
6.4L w/ 4:10
If you are going to run the sleeve, coat it with some chassis grease, prevents rust & seizing, plus no rattling!
I bought the adjustable hitch, but a 2"....the 2.5" was so much more money, could not justify the price increase.
Rotzilla
colorado
6.7 CTD
I had to purchase a new hitch pin after 2 years, the slack in the receiver caused the pin to bend.
I fabbed a shim from a sheet of metal that I slide in with the adapter to take some of the side to side play out.
Searay245se
BrookPark Ohio
2015 Power Wagon Laramie
Shim it and put a ton of anti seize on it and put a few tack welds on it then you won't lose it and can just cut the tacks off if you want to go bigger.
joshhhh
