I am sold!!! " that thing gives me a chub"!!! I will be ordering that after I get my mufflex. that thing is perfect!!
also 3 options for the 2 inch version too. 10 inch drop seems like a lot and probably more then i'd ever need so gonna order the 6 inch when i get some money.
any idea if you can get other ball sizes or even replacements for the ones it comes with? looked around the site a bit and didn't see anything but there's so much it's hard to filter through
It would be perfect if it came with a hitch pin lock that used the same key.
You can always get the Bolt brand hitch pin that "learns" your Ram key. I have one. I never really remove my hitch but atleast if I need to, I just use my truck key.
http://www.amazon.com/Bolt-Lock-BLT7018448-Receiver/dp/B005FNKFY8
[sarcasm]What truck key?[/sarcasm]
Keyless enter and go, biometric entry at work, and smartphone based entry at home. I literally only carry the FOB around.
My key fob has a key hidden in the end you put a key ring though-opposite end you use to start the truck. You slide a little release and a back up key pulls out. maybe fancier more expensive rams don't come with this feature. they probably assume you'll just call your roadside service instead.
