Hitches/ balls
Ratket
Ratket
Arizona-
I am sold!!! " that thing gives me a chub"!!! I will be ordering that after I get my mufflex. that thing is perfect!!
loveracing1988
Clarkston, MI
There are 3 different versions for 3 different drop lengths too, this was the middle one.
Andy578
Ontario, Canada
2014 Outdoorsman
also 3 options for the 2 inch version too. 10 inch drop seems like a lot and probably more then i'd ever need so gonna order the 6 inch when i get some money.
any idea if you can get other ball sizes or even replacements for the ones it comes with? looked around the site a bit and didn't see anything but there's so much it's hard to filter through
loveracing1988
Clarkston, MI
https://www.weigh-safe.com/shop/
Maybe call them or email them and find out? They don't show anything on their website either.
Ratket
Ratket
Arizona-
I am sure u can order it that way.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
NewBlackDak
6.7L Cummins
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
Those are nice setups. I just wish they made a "pretty" pintle hitch setup. Looks like I'm stuck with the large black mounting plate type.
jwheeler
Washington
[sarcasm]What truck key?[/sarcasm]
Keyless enter and go, biometric entry at work, and smartphone based entry at home. I literally only carry the FOB around.
Look inside the fob
reek
Sacramento
My key fob has a key hidden in the end you put a key ring though-opposite end you use to start the truck. You slide a little release and a back up key pulls out. maybe fancier more expensive rams don't come with this feature. they probably assume you'll just call your roadside service instead.
loveracing1988
Clarkston, MI
They still do, it is pretty much the same thing only there is end of the fob to stick into anything.
NewBlackDak
6.7L Cummins
I do know there is a key in there that I pulled out the first week I had the truck, and never looked at again. Hence the [sarcasm].
First world problems.
