hook a brotha up
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Wow thats impressive only 29k on an 03... it dont move much does it?
kajunboy89
kajunboy89
nope, and picked it up for 9k too.
kajunboy89
kajunboy89
well, it was an ugly game, but we won
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
i have spacers properly installed on my 2500, and they thrash my ball joints to an extreme. brand new ball joints are toast withint 10,000 miles or less. once i have the funds, i will be installing spindles.
kajunboy89
kajunboy89
not good guidry. no spacers for me. new springs and shocks or spindles only
matt99
Shreveport, LA
I would get spindles if I had it to do over again. Im pretty unhappy with the ride of the spacers (not the look though haha). Since the spindles DROP the wheels, essentially lifting the front, you have no change in suspension geometry which will not affect ride at all.
You MIGHT need new brake lines but with yours being under an 06, I think you will be alright. The 02-05s mount in a different position so it allows for more play.
Airbagit spindles are $300. Of course you need an alignment after that. But not bad IMO. For the cost of the spacers ($90ish) plus shocks ($150-200) you really arnt in that much of a different price range. Both can be installed in your garage.
OlDirtyJohn
stock spindle on the left, lift spindle on the right. the lift spindle moves the mounting point of the wheel 3" down, thus raising the truck up 3". everything else remains the same.
kajunboy89
kajunboy89
so, would i need new control arms with spindles?
still more or less leaning toward the rough country 3"... new springs and 4 new shocks for 300... dont think it would damage the truck that much either..
kajunboy89
kajunboy89
when i got on their website, saw they had an option with control arms lol and it says
Adj Carms Recommended
unless thats their way of asking for more money
kajunboy89
kajunboy89
and all this offset wheel **** is confusing me
OlDirtyJohn
dude, bigger springs are basically the same thing as adding spacers. i would highly recommend new control arms and shocks of you go that route. if you do the spindles though, all you need is the spindles. all suspension remains in the oem configuration. no change in handling or how the truck rides.
if you want to go even higher though. you can do spindles AND springs, new control arms, and shocks. this will net you about 6" in lift.
the only reason i am leaning you towards spindles is because i have 2.5" spacers (which is basically the same thing as 2.5" longer springs) and i hate them. the angle it puts my control arms/upper ball joints is ridiculous. my ball joints are always thrashed. if i had to do it all over again, i would have saved up my money to do it right the first time. which is spindles.
kajunboy89
kajunboy89
OHHHHH, NOW I UNDERSTAND... SPINDLE IT IS!
Use Lift Spindles on STANDARD O.E. OFFSET Wheels ONLY. Using an offset Wheel other than factory offset causes stress on spindle shaft & bearings and they can break!!
so that means stay stock rims or get new rims with the same factor offset?
kajunboy89
kajunboy89
all you had to say!! that sold me!
OlDirtyJohn
are your stock wheels the 17" or the 20"? if you have the 17's they have too much backspacing. spindles need a wheel with no more than 4.5" or backspacing. factory 17's have 5" of backspacing.
kajunboy89
kajunboy89
i have the 17" wheel. i would need after market wheels or the stock 20s?
Arturo Rojas
