Hope someone can help me pin point
TexasCornBread
Old River,Texas
5.9 magnum
Ok so I think this is a fuel issue but I may be wrong . It happens more if I leave my truck and not run it for a week or more . It just turns over 5-6 seconds then starts now it has happened before just sitting for a few hrs or 20 mins . I believe I have a problem with the fuel pump it acts up sometimes .
Now can someone tell me if its
Fuel
Spark ?
Truck has plenty of power but keep in mind she has 197xxx on her. Burns a small amount of oil upon start up . Nothing major .
I do NOT have a plenum upgrade
Please give me some ideas
If you can't dodge it RAM it !
reefguy89
laurel de
can you hear the fuel pump when you turn it on? Also how old is the battery?
TexasCornBread
TexasCornBread
Old River,Texas
5.9 magnum
Battery is new fuel pump yeah I can hear it . If you drive it for a long period of time and you get out with the truck running it sounds like the fuel pump is vibrating the tank cause u can hear the humming of it .
Hotroder383
Washington Mo
318 or 5.2 which ever you want
Sounds like your loseing fuel pressure after letting it sit. And if you hear the pump "humming" that loud you prob have an internal leak. I'd start by checking your entire fuel system for wet spots then replace the pump.
TexasCornBread
TexasCornBread
Old River,Texas
5.9 magnum
I want to put a high velocity pump in it will it work ?
ameer73
