Hot/Cold Air
sbecknal
So here is my issue regarding a/c vents. I get flow through the vents but not the floor for heater or dash for defroster. Hot on passenger side, cold on driver side. Any suggestions? No noise from blend door actuators either.
jws123
nj
One of the accuators most likely failed a good scanner will tell you what one or you can just tear things apart and see what one is not moving.
Socalramfan
Huntington Beach
2011 Big Horn
Yep, as mentioned above. Doors are not in sequence.
danielrly
Washington State
This happens to me as far as Driver side not real hot, passenger side normally HOT when set to max heat. Also it doesn't seem to blow strong air.
If this is a actuator hot big of a job is it?
Thanks
