Sgambots91
Installed Bilstien 5100 up front at 2.8 along with Mevotech UCA’s. Drove for a little over a week before taking it in to dealer for alignment. Definitely noticed the alignment was way off while driving.
After alignment dealer said everything is good except the caster is off a bit because the control arms. They said I won’t have premature tire wear from this because everything else is within spec.
Just want to share my before and after specs here to make sure I am good. I do notice I have to correct the steering more often than I did when it was stock but I’m guessing that’s due to the caster. I’m not really worried about that. My main concern is tire wear as I just put on some nitto ridge grapplers recently.
