How can I tell if I have projector headlights!
caulk04
Supporting Vendor
I'm no expert on 5th gens, but I don't think there are any projector lights in the lineup.
Base halogen reflectors and it seems two different versions of LED headlights which are also reflector based but different shapes.
Edit- this was originally posted in the 5th gen sub.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
on the high end dt rams longhorn and limited they have projector led headlights that turn in the direction you are going there will be 2 distinctive lenses on each side the rest are reflector
@Jacobian if you have a '16 truck(Gen4 DS body) the OEM projectors for your truck look like this:
the other headlights available on the body truck is a Quad which looks like this:
J
Jacobian
Here’s what mine look like
Those look like the Quad headlights, the OEM ones use H11 bulbs in the low beams and 9005 bulbs in the high beams
augiedoggy
western NY
3.0 Ecodiesel
Yes those are the base model "Quad" halogen refective housings. projectors always have a round magnifiy lens in front of the bulb. I upgraded from the quads to projectors a few month ago on my 2015. it was a worthwhile update and changes the look of the truck.
rule18
Admin
NY
2017 Rebel
I believe the OP has a 2016, so 4th Gen.
caulk04
Supporting Vendor
Yes, which is why I edited my post and noted it accordingly.
JonnyL
California
6.7l Cummins
Thats exactly what I am looking to do to my 2014 Ram 3500. Which year will fit my 14? Anything up to 2018? And is it all plug in play wiring or do you need a different wiring harness?
augiedoggy
western NY
3.0 Ecodiesel
You need headlights that state they are replacements for the quad style headlights. Many are compatible with both as they come with a wiring harness to go from the factory projector style plug to the halogen/quad style plug. The tail lights is where it gets tricky since you cannot use oem led style replacements in the trucks wired for bulb style oem taillights unless specified. I went with thses spyder lights since I was on a budget with lots of upgrades to pay for.
