How fast are your windows?
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I'm curious, I think there is something wrong with either the window motors or the electrical system that powers them. If i try and put up my two front windows from fully down to fully up at the same time it takes 5 seconds for the drivers window and 7 seconds for the passenger window if I press both at the same time. It takes even longer for them to go down. If I do one at a time the driver is a little quicker but not much and the passenger comes down to around 5 seconds. Is this just a dodge thing or a motor thing or a electrical thing like an alternator? Granted my truck is 10 years old but I don't want to replace the motors if it's the alternator or something else that's the issue.
Cthulhu
Calgary, AB
Cummins 5.9
Is the engine running when you do this, what does your volt meter show both before and during the roll?
They do sound a little slow. It could be the tracks binding.
02blkram47
02blkram47
Lebanon, NH
yes the engine is running, i'll have to look at the volt meter. I don't recall seeing it move to much but I'll check again.
WhiteExpress
Midland, TX
Manufactures are cheap. I'm sure they used the smallest possible wire, which ALMOST melts, but not quite.
There is a shorter run to the driver motor than the passenger, so the motor gets more current, goes faster.
suzukiquadrider
cummins 5.9, 6.6 duramax
Mine does the same thing the passenger window is really slow compared to the driver window.
WhiteRam
Dallas, TX
2012 2500 CCLB
6.7 CTD
My driver window went out before I deployed in Sep last year.
Still haven't got it fixed.
I'm just to afraid to take it in and come out with some huge bill.
Birdman-68
New Baden IL
Mine are uneven too, but not quite as much as you described yours. Maybe 1 second difference going up or down.
Notorious
City of Angels
It's not limited to Dodge. My Ford was worse. The passenger window took twice as long as the other windows. Every Ford I drove was like that and it got worse as time went on.
Never experienced it in the BMW or Porsche or Lexus or other non-American cars though. Maybe it's an American thing?
TheMaddog
DFW
Depends if I workout or not. I can beat most automatic windows on a good day. On a bad, I just say eff it and open my door. I workout hard
nussdawg395
PA
5.9 Magnum
My 02 is the same. I was actually just thinking the other day i cant believe that they are that slow going up even with the truck running. I'm not worried tho, if it goes, I've replaced a **** ton of window motors before and its cake.
josephw
Meridian, Ms
5.9 magnum
neither my pass or driver window barely moved but i was able to figure mine out. Im not saying this is what will fix yours but here is an explaination of what was wrong with mine. The window run channels and their mounting brackets are thin and are very easy to bend. I pulled my door panels off to look at the motor and realized that my run channels on the pass side was pinched in the middle and the driver side one was bent. For the driver side i jus bent it out a little at a time, testing the window speed until
it was no longer binding. For the pass side i took a wide flat head and pryed the channel back open,of course testing the speed until bind was gone. If you open it up too wide you can get a rattle if you have your window cracked and you close the door. My speed is about 2.5 to 3 seconds fully open to fully closed now. Again, i dont know what your issue is but this is how i fixed mine. I guess the channels just bend over time because theyr so thin. Hope this helps!
ben.orts
Bulverde, TX
Yeah mine too. I'll hit them at the same time and the driver side usually wins the race.
Sagebrush2500
2013 2500 Big Horn
I drove into a sudden rainstorm the other day and my windows couldn't be fast enough.
Good question about putting some lithium grease on them. I used to do that with old wind-ups and they'd spin up and down with a touch to the handle (exaggerating a little, but you get the point).
ercmesser
Tampa, Fl
Remember white lithium grease spray. Its the best way I found on putting it on. And when you are in there you mite want to hit the door and locking mecs too. It doesnt hurt to lube up them.
