How loud is a Catted Y-pipe
R
Rogues Gambit
Guest
First of all, just got the truck tonight (Rebel), although it's too dark for good pics, so I'll upload more tomorrow as well as make a dedicated thread tomorrow
Besides getting acclimated to the size, also find it a bit too muted for a burly V8, though while I research exhausts and mufflers, considering a Y-Pipe after the CAI.
That said, how loud would replacing the factory Y-pipe with an AFE be, just nice enough or into obnoxious territory?
Thanks in advance
Rogue
Nick@GotExhaust
Supporting Vendor
SC
Congrats on the new RAM! Looks good
Why not do a muffler kit or catback instead of changing the Y-pipe for more sound?
Let us know if we can help with the intake and exhaust and anything else. We offer just about everything and offer discounts to all the members here!
R
Rogues Gambit
Guest
Thanks Nick
Just use to changing the Downpipes on my turbo 4's first, so figure they're similar
I'll take a look, though like I said, something mean when I want it to be w/out it droning or setting off alarms (just yet), just something to show it has Ball's
JoeCo
NY
Would have to agree, not sure how much switching y pipes would change sound but know for sure a muffler swap will wake that thing up. Or cut outs, next truck I have I'll probably just do cut outs.
Nick@GotExhaust
Supporting Vendor
SC
Thanks Nick
You wont get the same effect as a turbo 4 by just swapping the y-pipe. It also depends on how much you want to spend. We have a ton of options. we can set you up with just a cat back that will offer more volume than a catted y-pipe or we can do a full setup, headers- y or x pipe and a catback. IF you want guaranteed NO drone at all then you gotta go with Corsa.
R
Rogues Gambit
Guest
Guess I'll wait for Corsa, what
Yup, thats what I thought. It will add some sound but not like a catback exhaust or muffler kit would.
But I see it free's up power, that's what else drew me to it. Figure that and a AFE CAI to start with, then I'll figure out which exhaust I wanna do.
How is Corsa, figure if @DRkNESS is interested, I should be as well
DanBen
Skaneateles NY
There is a lot of information on this forum about different exhaust mods from muffler deletes, performance muffler replacements, and cat back replacements. The OEM exhaust is already 3" stainless steel single pipe to a big (quiet) muffler, single out to a Y and then dual out to the tips. The OEM has 3 resonators - one before the muffler and one on each dual exhaust pipe to make the truck very quiet. The 2019 is quieter than the previous generations with larger resonators on each of the dual exhausts.
I agree that we need to hear our hemi but I did not want mine as loud as my son's 2017 with muffler delete (pipe replaces muffler). The first thing that most of us Harley owners is to replace the stock exhaust to hear the rumble, to what degree is the owner's preference.
If owners want the loud sound then the muffler delete is great but can be obnoxious to many. Muffler delete is just the removal of the muffler requiring one cut after the muffler before the Y and a replacement pipe setup with proper bend and flange.
If owners want a simple way to increase the exhaust sound but have a "tuned" rumble tone to it then a muffler swap is an economical way to go. There are several different muffler choices out there and some offer a simple swap setup similar to the muffler delete setup.
You could also go with a cat back system that will replace the muffler, dual exhaust pipes and dual exhaust pipe resonators, and exhaust tips from the exhaust pipe flange about half way back under the truck. Great tuned systems but more expensive system with nicer tips.
The replacement performance mufflers can be anything from straight glass packs or turned glass packs with glass insulation around the baffles to mellow out some of the exhaust sound or could have metal internal diverters to tune out some of the sound
- all without providing much back pressure.
I went with Flowmaster Super 44 replacement muffler which provides a mellow rumble that you can hear well at cold startup, slightly during idle, and more when you get on it with very very little drone. It makes me feel good to hear my hemi, one of the reasons I bought the truck, but not too loud and definitely not obnoxious.
I cut out the OEM big muffler and installed the 3" Flowmaster Super 44 with inlet offset and outlet offset to line up with the existing pipes (similar to the OEM) and added a 12" + long piece of 3" SS pipe. DYI system with proper clamps - hanger rod/clamp can be difficult. I made sure I really like the sound, which I do, and I will go to a shop to have the rear clamp replaced with a permanent weld.
Many other systems are available at different price points.
My wife was skeptical since we just bought a $60k "luxury" vehicle that was super comfortable and super quiet and I was going to DYI modification - The exhaust modification gave the truck the sound it needed and makes it even more enjoyable. My wife likes the mellow rumble also better than the quiet stock exhaust.
R
Rogues Gambit
Guest
Definitely gonna consider it after I some stuff sorted out first, definitely on the list
Of course, also gonna check out Corsa, but for now, first performance mod will be the AFE Magnum CAI
Nick@GotExhaust
Supporting Vendor
SC
Let me know if you would also like a quote on the AFE intake. We offer them as well as pretty much everything
