Jovac
- Mar 11, 2025
- 6
- 1
- Location
- St Louis, MO
- 2020
- Cummins 6.7 TDE
I have a 2020 2500 with the Cummins. Did a valve body swap and fluid/filter change. Also replaced the pan with a deep pan. Everything seems okay with it but I can’t seem to get the fluid up to the right level on the dip stick. At operating temp, it looks like it comes about midway between cold high and hot low. I am concerned because it’s taken 13 quarts so far. I keep adding in small increments but need a sanity check that I’m not overfilling it. Anyone have any insight whether this sounds right?
Seems to be shifting correctly and running at same temps it always has. About 168.
