How much to cut for 1"/2"
PassivAggressor
I want to lower my truck a little bit and don't feel like a 2/4 is right for me. I was thinking a 1/2 would be great because I still want some rake and I wouldn't have to touch the track bar. I have a 2014 rcsb express. How much spring should I cut on the front and rear to achieve that?
DTECH
Lancaster CA
start with a 1/4 coil at a time..I know it sucks to have to but when cutting coils its better to take a little put it together and drive to let it settle then measure if you like it leave it if not remove another 1/4 coil. do the front first then rear. use tape or a wire to mark the removed area on each coil so you cut the exact amount from each coil...
Reticle918
