How to change a shock eye bushing
joeg45
Katy, Tx
This isnt my first time but a way I finally figured to change a shock eye bushing pretty quick. I had taken almost an entire day to change one one day and ended up with this.
The only reason I'm changing these is because I was a ******* and ordered the wrong ones and the shocks had to be changed that day lol so here I am showing you guys and easy way because I never found a good how to that didn't need to purchase something else. So I'm hoping this will help someone in need of a bushing change or is buying shocks that don't have the right bushings but the right needs.
All the tools I used are in this pic except I also use the shocks own bolt in the process you'll see later on
1 Hammer/ dead blow
2 13/16 sockets
1 5/8 washer (only applies to shock bolt size)
1 Sharp knife
* Bushings
2 ratches (the air ratchet makes it much faster)
1 extension
1 crescent wrench (don't need it but it helps some)
* lube of choice
1 shark (bottle opener lol)
The extension is the easiest I found to take off the top shock bolt with out a fight
First I cut off one end of the bushing being replaced to easily remove it
Now just push it out
This is were the bolt comes In I use the washer as a backing so the bolt won't go through when you tighten it spray some lube or get some grease and make sure the bushing stays aligned with the whole and go slowly at first to insure this then once its in you can speed it up
Then once its in maybe 3/4 or till it won't push in anymore back off and hit it in the rest of the way with the dead blow or softish mallet
And you see the difference in the first one I ordered and this one lol
And your done :D
BlkRamRt
SoCal
HEMI 5.7
good stuff how do you like those shocks.
joeg45
joeg45
Katy, Tx
These shocks are amazing I can go from it driving like a cloud to as sproty as I want now I'm wondering g about the inside controller I read about some were so I don't have to go under
BlkRamRt
SoCal
HEMI 5.7
that controller would be nice. now you have me thinking about getting new shocks...lol
UNBROKEN
2012 Ram R/T
Hands down the best shock you can put on these things. The fronts are a pain to adjust but on the back I aimed the knob forward...I can just reach through the wheel and adjust them without laying down.
joeg45
joeg45
Katy, Tx
Seems high price at fist compared to the bell tech shocks but they are worth it wish I had gotten them a lot sooner
Yea I figured that out when I put on the fronts I was like damn do I have to unbolt it every time to adjust them then my fingers squeezed in. backs are very easy to adjust
BlkRamRt
SoCal
HEMI 5.7
do you happen to have the part #'s
joeg45
joeg45
Katy, Tx
I used ts505 for the front and ts901 for the rear ( for single adjustable)
On the back you need to find new sleeves I machined my own 3/4 OD and 9/16 ID I believe and the front t-bar needs to be a longer one that qa1 also sales
BlkRamRt
SoCal
HEMI 5.7
i used ts505 for the front and ts901 for the rear ( for single adjustable)
on the back you need to find new sleeves i machined my own 3/4 od and 9/16 id i believe and the front t-bar needs to be a longer one that qa1 also sales
cool thanks for the info.
BlkRamRt
SoCal
HEMI 5.7
One more question for the t bars did you buy them from qa1 i see they have kits that are 3 - 3 1/2 and 5 inch
joeg45
joeg45
Katy, Tx
I believe its the 3.5 bar
For maybe some savings I usually order all my stuff from jegs they price match everything and usually free shipping
BlkRamRt
SoCal
HEMI 5.7
Great.. I think im going to order the front ones first around nov-dec time..thanks for your help.
joeg45
joeg45
Katy, Tx
Not a problem and I'll measure the ones I have when I get home to be certain I didnt bring my truck today I stole my wife's car for work lol
BlkRamRt
SoCal
HEMI 5.7
not a problem and i'll measure the ones i have when i get home to be certain i didnt bring my truck today i stole my wife's car for work lol
sounds good. Thanks
JustinRam1500
