How to disconnect fuel lines at tank?
wrenchinup
Bozeman MT
Cummins 5.9
97 diesel, can’t figure out how to disconnect the fuel lines at the fuel tank, one guy said to push two clips in at the line side and with other hand pull the line back but I don’t see the two tabs and can’t fit both hands in there. Any suggestion greatly appreciated. Is there a special tool for it? Thanks
Dan98
You can buy the line tool or rent one 10 bucks or so really easy seriously.
Sent from my SM-J260A using Tapatalk
patrickocake
Missoula, Montana
Magnum 5.9
There are different types of fuel lines with Rams. Some you will have to depress and twist the connection. Look up which type you will have. Get a picture of what is actually on your truck, and cross reference that online using images.
I bought a Haynes manual that shows me 4 different types for the same year and series as my truck. I just eliminated what wasn't with what was actually connected.
I hope this helps some...
dterrel
