Rubber fuel lines
wej
5.9L turbo Cummins
Going though a '96 5.9L 1500 I picked up earlier this year. The backplates are rusted out, so hitting the local pick and pulls, since they have some newer year candidates. <$30 beats $240 for the pair. Brake and fuel lines are rusty and gauge doesn't work. Thought I would replace everything that needs to be accessed. Got a set of pre-bent SS brake lines and found a pre-bent fuel line at a good price. Found an old stock Airtex pump at a great price. Can't find pump to hard line hoses, except hard line to rail. From what I read, the fuel lines are pressurized to rail pressure? I'm looking at 6AN push/click hose adapters. Anyone have any experience with this? Any special tools to use? I don't see the sense in using the old hoses. Couldn't find anything using search.
Tank Guy
Western Pennsyvania
Cummins 5.9
You might be able to find something if you have the part numbers you're looking for. If you don't have the parts manual for your truck, a dealership parts guy can look it up for you. They can also do a nation wide search of dealership inventory to see if anyone out there has one sitting on a shelf somewhere. I just located a very hard to find transmission oil cooler line for my 2002 Dodge Intrepid through a search of the dealership network.
southalum
