How to fix my mushy transmission shifts.
Jough Blough
Minnesota
I am the original owner of a 2008 dodge ram 1500 4 x 4 quad cab. It only has 108,000 miles and has always had mushy shifts. Does anyone know how to connect with the transmission computer to improve shifting to a more firmer shift?
J
Jough Blough
Minnesota
Shifts firmer but at higher rpm. I was hoping to get it to shift up firmer at lower rpm and lighter throttle for better mileage.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I notice it lower in mine when I use the tow haul button, but my tranny is built and has a shift kit. Was hoping it would help in your case.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Somebody has to make that already.
I have an Edge Juice tuner on my truck. It does allow you to reprogram the shift points. It's "vehicle specific" so I don't know if it's available for your year and model, but I have to believe if I have this, you can find something. Maybe even a sport shift add on with paddles. Heck, maybe even from a Dodge Charger or Challenger.
HemiLonestar
Navy Badge Coast Guard
MD
Older Superchips tuners were capable of reprogramming the shift schedule if the option was purchased. No one bothers with the RFE anymore.
I would like a device that would allow me to shift it manually.
You can, unless you mean being able to specifically select ALL gears. Then no, not doable.
Tray Burge
On the porch
I have an 03 and to my knowledge, it's the only model year you can actually disconnect it?
It was like adding a shift kit afterwards it shifts so hard now.
Best free mod I've done.
HemiLonestar
MD
That's disconnecting torque management (aka TMR mod).
SSGTD
