How to fix this small lift
Chief115
As my truck sits now, I bought it with a 3in lift in the front, and apparently nothing was done to the rear as it sits like it's towing something. I think it looks stupid as ****. How do I bring up the rear so it sits level?
Also, I'm thinking about changing it to a 5in lift, and putting 18-20 rims with 35 tires. Any thoughts comments or suggestions?
B-Shot
You can use the super lift SLF-4038 3" kit for the rear which can be had for 50-70 bucks if you shop around which would level the truck.
C
Chief115
Thats great info. Ill be sure to check it out tonight. Have any thoughts on a 5in lift ?
B-Shot
You could do a 3in body lift for 200-300 bucks and you would 6" over all. A 5" suspension lift done proper would be $1200-2000. maybe others on here will chime in that have done a 5+" lift
BBartow
New Port Richey, Florida
5.9L Magnum
2" AAL in the rear to level it. Much better choice than the blocks.
Easiest and cheapest solution for 5+" lift would be a body lift. 5" Sus. lift would require you to replace what you have and add some. Cost $$$.
Johnn123
Ontario
I agree with the others, get some 2" AAL's for the rear and then get a 3" body lift to go on top.
Merc225hp
NA
truck
gas
Body lifts are deff a cheap way to get some extra tire clearance.
C
Chief115
That's a good point. My main goal is to get some real functionality (aka off road) while still keeping on road.
C
Chief115
Also I'm a noob when it comes to lifts. So 2in AAL is what exactly?
BBartow
5.9L Magnum
"Add-a-leaf". You add another leaf spring to your current leaf pack. Cheap way to add lift, but will stiffen up the rear a little bit.
C
Chief115
Ahh that makes sense. How do you think that will change my off road ability? I wouldn't think much, but then again I have next to no experience with all that
Johnn123
Ontario
Wont affect it, if anything it will help it.
C
Chief115
Really? Kinda counter intuitive right
Merc225hp
NA
truck
gas
Using a body lift will let you run a bigger tire, that equals more frame to ground clearance, not as much as you would gain if you went with a true suspension lift. I will keep my op about body lifts to myself. Get on it op and post up pix of your work.
