Hyper flash
e_hartzell17
I have put in switchback led turnsignals on my 2001 1500 and even with the resistors, hyper flash still occurs, but not all the time, sometimes it does and other it don't, it makes no sense and all connections are good
BEAST19
I had to wire my resistors in with both end of resistor wired into the ground wire of harness. However mine is a 2015 but give it a shot . Works perfect now ea3b48675fe1a8ba6a869ad0cf542cca.jpg
e_hartzell17
e_hartzell17
Wow that's really weird but I guess it's worth a shot, but it makes no sense that it only sometimes hyper flashes
dapepper9
Iowa/Nebraska Border
5.9L V8
My suggestion, remove resistors and clean up wiring, make the rear turns LED as well, swap in an LED flasher relay. That's what i do in my 01. Factory function and cleanliness with aftermarket look and visibility
BEAST19
Mine would work perfect with the engine off . Once I turned the engine on it'd blink normal a couple times befor huperflashing. . That's what made me try the ground resistor.
e_hartzell17
e_hartzell17
Well that's what I did my rear tails are all led the only thing I don't have is an electronic flasher relay
crazzywolfie
under the truck
well that is likely the best and cheapest place to start. a new flasher relay was probably cheaper than the resisters you bought.
e_hartzell17
e_hartzell17
Resistors came with the bulbs but ok will do I'll get one and see if that helps
Fryekenn
