I don't want headlights on when I unlock the door-any why to change it?
dexter
Banned
When I use the key fob to open the headlights go on.
Is there a way to stop that?
I checked the set up on the Uconnect. But I didn't see that option.
I may have missed it.
R.L.K.
Bristol , Tn.
If you have the touchscreen radio either the 5.0" or the 8.4" you can do it there in settings . If you do not have the touchscreen then it's done with the settings in the cluster evic settings using the arrow keys on the left of the wheel .
I believe you can do it from both locations if you have the touchscreen.
Hemipower95
Go to settings- lights- uncheck flash light with locks however, your mirror lights will still light up when you unlock your truck if equipped
For 8.4
D
dexter
Banned
For 8.4
OK - that helped but it is different on my screen it is:
Go to settings- lights - on approach - then set it to 0 seconds.
That's why I couldn't figure it out the first time.
Thanks for the help.
