I need a good black exterior spary paint
Danimal77
Pontiac, IL
In early august I will have had my Ram for 2 years. The truck is basically flawless with only 7600 miles on her. The only exception is the underside of the truck. The road salt from our wonderful Illinois winters has taken it's toll. Everything has a light/spooty surface rust. My main area's that I would like to address are the hitch and the rear axle. I just changed my diff cover last weekend to a PML, and noticed that I need to do something to spruce her up. Can anyone recommend a good gloss black exterior paint that will hold up. Like I said, the rust is extremely light and in most cases a soapy rag makes a big improvement. I was just thinking of a light sand job then hit it with the rattle can. Any suggestions are greatly appreciated!!!!!!!
Bad Habit
Land O Lakes
Modded 4.7l
I would use a flat black to be honest that way it matches what is there and gloss just looks like you went under and sprayed it but that's up to you and I would use a rustoleum can they seem to have good rust inhibitors in there or you could look into some thickr under coating made for the underneath of the truck...sp
OklaHemi
new age hemi
dont forget the primer
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
man......I thought I didn't drive much!
cheapbeater
Wisconsin
i used vht epoxy paint on mine. scuff with a red scotch brite, wash, dry and spray away. i used about 5 cans to do the entire underside but it was kinda windy out...
damn, it looks good!
08QuadRam
You should use rustoloeum paint. I use semi-flat paint. This is the closest I've found to 'stock'. Makes your truck underneath look amazing.
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
i use krylon bbq paint. self leveling, stands up to 1500*F so it can paint anything surrounded by the exhaust
ramhunter9
P-Star Jeep Wrangler
having a company truck is a nice perk. The Ram usually only leaves the garage on weekends.
tell me about it ..lol love the company gas here also
RubberFrog
This is what I use and it looks fantastic!
mvm2
