I need advice On Tire size and Rim offset
scmowry
cant wait to get home and work on it in a few weeks. I will for sure post pictures. Deploymet cash burnin a hole
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
If you need help with spending it. I'm your man.... Lol
But Jake is right. 1.25 is not noticeable in gaps.
scmowry
Hey guys this is killing me. I have been taking your advice and I still cant figure this out. I feel DUMB!!! At the end of the convo people keep saying get a BL. I just want the 6' lift Bilsteins and a 1' rear spacer. Can I run a Toyo 37x1350 20x10 -24 offset with this setup????or will I have major issues? I just need someone to tell me what to run here lol
fastNugly
Toronto, ON
You will rub and this is 100%
To ONLY run a 6" lift up front, you will need a 20x9 wheels and a 12.5" wide tire
0 offset will not rub AT ALL, -12 you may be able to get a way with on a 12.5" tire
But you will not be able to fit what you want above with only a 6" lift
Even with a 1.25" body lift you will rub.
You need at least Bilsteins at 2.1 to fit it and that too may require some trimming as each one of trucks are different
Hope this helps
jake09
set at 2.1" you can run 20x10 -12 offset with 12.50s and be fine i know..13.50s on that should be ok also..with -24 offset it will prob rub on the plastic valence some with 12.50s or 13.50s...you have the chrome bumper correct? not the sport bumper?..I've seen a few members run around 7.8" lift or so on -24 and 13.50s..kevin (musclemckeester) ran this setup before body lift and just removed lower valence to make them fit.
I'm telling you man..sick setup would be 6" rcx bilsteins 2.1", 1.5" rear spacer, and 1.25" or 1.5" body lift, 37 1350s on 20x10 -24 offset...wont rub and sit perfect..only thing will have to do is adjust exhaust tips after body lift..But if you are that against a body lift and not running huge 2.5" fender flares get 20x10 -12 bilsteins 2.1" with 12.50s (13.50s even and trim valence some or remove..i removed mine even)
fastNugly
Toronto, ON
This ^^^^
scmowry
Thanks guys! It sucks because there is NO ONE in my state with lifted 4th gens. Its crazy. You guys are a life saver!!!! I just gave my Wife to be a heads up that she will have packages on the way. Just ordered the 37x 1350 Toyos, with Fuel 20x10 -12 offset wheels. My RC 6'Kit with Bilsteins and my 1.5 spacer. woooooooooo that was a lot of cash spent real quick!!!!!!! 34 days till Im home and can see it all! PS. I have the Sport bumper.
jake09
Going to look good man!! sucks droppin cash like that though doesnt it lol
scmowry
usually yes, but I havent spent a dime in a year so its time lol So excited. I never thought id have 37s.
jake09
Similar setup you will have..6" rcx, bilsteins 2.1, 20x10 -12 fuel throttles, but on 38" toyos and 1.25" body lift also. and only has 1" rear spacer.
scmowry
That looks good! So since I have the sport bumper, does that make it easier? Im about to purchase a tuner and a 87mm TB too. See what happens when boredom hits!!!!
jake09
Shouldn't make a difference...but the sport bumper will give some if they rub so good to go haha..You'll be fine though..I want an 87 tb pretty bad! Last thing I'm doing actually for awhilleee
scmowry
I need all the performance I can get. 3.55 gears here! OUCH!
jake09
yeh you will prob want to upgrade to some 4.56s or so but as long as you aren't in really hilly areas you'll be good till then atleast..My stock 3.92s pull my 37s really good actually
scmowry
I cant find a shop to instal the gears. God knows how much it would be to swap the axles :(
fastNugly
Toronto, ON
OUCH! That is correct!
This is what I had before re-gearing.....lets just say, my truck was back in the shop for the gears exactly 2 weeks later after lifting and 37's
This is true ^^^
Where do you live?
j4m3s
Maryland
So having 3.55 gears and going to a 37" or 35" tire, the truck should be re-geared? :/ What would be a good gear for me to look into? I do a good mix of flat and hilly driving.
