BlackRamHemi
- Aug 14, 2013
- 1,266
- 557
- Location
- Edmonton Alberta Canada
- 2010
- Hemi 5.7L
I new to research front gear swaps for this as it has an IFS system.
IFS has nothing to do with it.
in 2011 Ram switched to ZF differentials/axles from the standard 8" Chrysler (front) and 9.25" Corperate (rear) they have been using for the last dozen years.
and no one in the aftermarket was making gear sets for the new diffs.
The rear carrier has to be machined to accept older gear sets, if you want 4.56's
and the entire front end needs to be swapped on a 2012 4x4 to a 2010 model front axle assembly
For a 2WD Ram , you could get a 2012 ZF 4.10 rear (part # from an R/T)
...but there still is no matching Mopar 4.10 gear set available for your front diff on 4x4's
read this link http://www.ramforum.com/f44/detroit_tru_trac_2011_zf-46567/
Your only other option for direct swap over is to use 2012 and up Mopar 3.92 gears and LSD.
