i plan to do 3 inch lift on my 2015 Crewcab Tradesman 8 ft longbed w/Cummins engine.
The hippie
cummins
i plan to do 3 inch lift on my 2015 Crewcab Tradesman 8 ft longbed w/Cummins engine. Do i need to change my tires?
T
The hippie
cummins
And also, does it affect fuel consumption?
kg93
AZ
you don't need to change your tires, more of a personal choice. I would get bigger ones though
shouldn't effect the millage much with the cummins, if at all
T
The hippie
cummins
Thanks. I don't plan to change the tires if it's ok.
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Nothing was going on in the second gen forums so im messing around in here lol but any time you lift, I would advise you increase your tire size unless you want to be the guy with "lifted truck, little tires" :roflsquared:
loveracing1988
Clarkston, MI
Yeah, the 33's almost look small on a stock truck especially in the rear. Adding a 3" lift isn't going to look very good at all in my opinion.
