idle problem
DDean
4.7 only does this sometimes but earlier the idle dropped so low it sounded like it was gonna shut off but didnt went back to normal. What can cause this
DDean
DDean
Did it in park
DDean
DDean
Anyone??
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
I'm sorry for the delay in my response..... was a little busy. Usually, when you have an idle issue it is because the IAC (idle air control) is either gummed up or dirty, or it's bad and needs to be replaced. Try cleaning it first and if that doesn't cure the problem then replace it. The replacement runs anywhere from $50 to $60 bucks.
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1440137&parttype=6072&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=1brpbvrspahov3vtai5a0gto02
More Information for AIRTEX / WELLS 2H1392
DDean
DDean
That was my first guess. Good thing i bought some cleaner a few days agi. Ill report back my findings
