Ignition systems
Ian_Olivas
San Antonio,Tx
4.7L Magnum
I've never really looked into it but I came across a youtube video of someone using the msd 6hemi ignition system. They used it with fast ez efi because it self tuned or some **** like that and they started it on the engine stand with no ecm/pcm.
2 questions. 1) does this replace or serve as the ecm/pcm? If so how? If not and someone has the knowledge that is willing to explain how the engine ran without the ecm please explain
2) what benefits is there in using a ignition system like this, if any
HemiLonestar
Navy Badge Coast Guard
MD
1) No, this simply controls ignition pulses and timing. It was originally designed for keeping the coil packs on a modern hemi with a carb; if memory serves this was also well before someone figured how to retrofit a distributor to the 3G. Does nothing for fuel control, strictly timing and firing plugs.
2) If you wanna fire the coils on a carb'd or standalone EFI system.
waidpa
