Shane R Tedhams
- Dec 22, 2018
- 20
- 8
- Location
- MI,US
- 2014
- 3.0L V6 Turbo Diesel
This is for a 2014 Ram 1500 Laramie Ecodiesel approx 135000 first p203e and approx 141000
About 4 months back the check engine light came on scanned it and got the p203e code. Drove it all the way down to 0 miles because the Dealership wanted 3000 to replace the tank. Well, I went the cheap route and after multiple attempts at fixing it I finally got it to work by soaking the tank in distilled water. About a month ago it came back! I drove it down to 12 miles and decided to soak the tank again. This time it didnt work. Here are the troubleshooting steps that I took and what the outcome was:
1. Drove it down to 12 miles remaining, siphoned out a half gallon of def because that's about all that was in the tank. Boiled 7 gallons of distilled water and put it in tank, I did not siphon out the water and refill with def this time. That worked for 1 full day driving approximately 40-50 miles and the "engine will not restart" did not come on at all. It was 37 degrees the day I did it and 25 degrees the next day. At 3PM (the day it was 25) the message popped back up and wasn't going to restart in 12 miles. I know the water partially froze but no guarantees it was a solid block of ice.
2. Disconnected negative and positive terminals put them together for 10 minutes to try and reset the ECM. That didnt work
3. Dropped the tank soaked it in distilled water(this is how I found out it was partially froze) refilled with 1 gallon of def fluid. Didnt work.
4. Spliced a capacitor reading 37pf onto pins 1 and 2 of the def sensor at the tank. Didnt work. We were hoping in theory that the sensor read in capacitance but we arent 100% sure.When we started it we had a P203e,d,b, and a couple others. Deleted them and have a pending p203d
If anyone else has any ideas it would be much appreciated. Since I have dropped the def tank I will spend the 1400 to buy a new one if I have to go that route but if someone knows of a cheaper easier way that would be awesome! Also I heard about an egr/def delete but I'm more of DIY kinda guy. If you have instructions on how to do it yourself go ahead and send them my way! Feel free to ask any questions. I have a very quick response time.
